custom IC piping/downpipe/intake piping: what mandrel bends did you get?
fiznat
Car: Grown up :(
The next step in my project is to fabricate the intercooler piping, downpipe, and intake piping. I'm about to order the mandrel bends, but I'm not sure exactly how much and what I will be needing. Obviously I'll be using some combination of 2.5" mandrel bent u-bends, straights, and possibly j-bends, as well as a flex section and possibly 3" pipe for the downpipe: but I really dont want to buy more (or less!) than I need.
Soo for people here who have custom built their piping: what did you get, how much, and where did you get the stuff from?
fastpace
Car: cars of course
Cost about 200 bucks from roadraceengineering. If I were you I would get some extra pieces anyway just in case you mess up. I had extra stuff after it was all said and done. I got 1 2" j-bend, 2" to 2.5" adapter, 3 2.5" u-bends, and a 2" straight pipe for the ic piping. For the downpipe all you need is 1 3" u-bend and a 3" straight pipe.
turtl631
Car: S14
Did you do 2" hot side, 2.5" cold side?
240SXmotoring
Car: 97/95/90 240sx
if you want to make it look BLING BLING....and maybe even tig weld it up you can go with aluminum U-bends
http://store.240sxmotoring.com/unaltugrsh.html
NX95240
Car: my KA-(sc61)
i got my I/C piping from JC whitney . both side are 2.5" i got 3-180, 3-90, 2-45. i had enough to do both sides. and i just power coated them.
skatanic28
Car: 96 240sx
you guys think mild steel would be alrite if i coated the inside so it doesnt flake? any recommendations for doing so?
daniel240
Car: cars/motocross
it would help if you could buy it locally that way you could take it back if you get too much. thats what i did the first time. recently i redid everything and i orded everything from jcwhitney and i just guessed at the piping and i ended up have exactly what i needed.
fastpace
Car: cars of course
turtl631 wrote:Did you do 2" hot side, 2.5" cold side?
2" for half of the hot side and the rest was 2.5 to complete the ic piping.
fastpace
Car: cars of course
skatanic28 wrote:you guys think mild steel would be alrite if i coated the inside so it doesnt flake? any recommendations for doing so?
mild steel is fine with fine with ic and downpipe piping. I have it for both.
fiznat
Car: Grown up :(
Cool, most of this sounds about what I thought I'd be needing.
For those guys who did seperatly dumped wastegates, how big of a pipe did you use for that dump tube? I only plan on bringing it back behind the front d/s tire.
fastpace
Car: cars of course
I used a 2" and was about 5" long pipe that was welded to my wastegate flange
240SXmotoring
Car: 97/95/90 240sx
yea 2" that is what we are using also on the racecar
