dangeris wrote:Sorry I have expensive taste but I like to do things uniquely on my coupe. Make sure you take pics of the product before you install them so we all know how it looks like before it is installed. Would be great if you took pics and documented along the way for a good writeup for everyone else wanting to do the same.
Trust if i could afford the projectors i would but i figure let me jus try something different.
But sadly this project was a FAIL
Not Totally though. I did in fact install the fogs similar to the way you did dangerous.
here's what i was trying to do. It could still work but every1 would need to shave down the bottom of the fog frame to fit in the Fascia space provided.
Basically i was taking the whole fog housing & trying to fit it into the spaces on the stillen fascia.
When i saw the pics on ebay I figure these are pretty close to the shaping of the slot & I might have to adjust the shaping slightly
As you can see there's still some spaces that need to be filled & the fog light does not fit perfectly of coarse. Also I did shave down the bottom of the fog a lil to fit into the slot. If I had someone do a more professional job maybe it could've worked out better. I will continue to work on installing the frame with the fog light but for now I only installed the fog alone.
This is the finished product. Maybe not the best of jobs but still looks descent to me & some of my friends that saw it in person today.
The fogs lights are slightly smoked. That's how i bought them. They still look clear though doesnt really do much at all
Here are some pictures with my HIDS
Man I've missed them so much!!!
