My friend and I are now making parts for 240s both s13 and s14 chassis we also make parts for AE86's to. All of our parts work and if there is ever a problem with the part I am always available to help. If you see anything that might need improvment please feel free to let me know as I am still new to this but I assure you all of the parts have been used and tested and work perfectly.
All of the parts are made of high quality stainless steel so no rust.
All parts are finished in black.
To purchase a part contact me at
[email protected]
Parts available now:
Cold Air Intake Hydrolock Plate Front Under brace Bar
Front and Rear Strut Bars
Cold air and short ram intake heat shields
Brake booster brace
Upper Radiator Cooling plate
Custom Headlights comes with headlights or without headlights
Parts coming soon:
X brace for frames
Rear Under brace Bar
B Pillar and C Pillar Bars
How the parts help:
Cold Air Intake Hydro lock Plate: This is the best upgrade for your car there is no more need to worry about hydro locking in the rain. With this plate it blocks all of the water from hitting your intake cone. It also has vents to allow air to cool down your brakes. Now you wont have to pay for a bypass valve that is way more expensive than its worth.
Front Under brace Bar: Our Under brace bar uses thinker tubing it’s made of high quality stainless steal it’s an inch and a half it bolts onto the tension rod housing.
Front and Rear Strut Bars: Our Strut bars are 1 piece not 3 so they don’t have as much flex as other companies and it’s made of high quality stainless steel. It’s a great product for the price and very durable unlike the ebay strut bar.
Intake Heat Shields: Stops the engine from drawing in hot air. Letting your car suck in colder air.
Brake Booster Brace: Stops the brake booster from flexing making the brakes feel stiffer and very solid.
Upper Radiator Cooling plate: The cooling plate forces air to pass through the radiator instead of passing over it custom fit so it wont hit your hood or keep it from coming up. Its cheaper than any other ones that you can find.
Custom Headlights: This is a stainless steel headlight design not fiberglass. Its light weight wont crack and wont rust its 100% street legal and its very durable with the deign we have.
Pricing for parts: All prices are without shipping.
Cold Air Intake Hydrolock Plate - $45
Front Under brace Bar – $50
Front Strut Bar - $60
Rear Strut Bar - $60
Cold air and short ram intake heat shields – $20
Brake booster brace – $15
Upper Radiator Cooling plate – $30
Custom Headlights comes with headlights or without headlights – $50 without headlights.
$110 with headlights comes with 4 headlights show in picture
Installation Instructions:
All parts come with installation instructions if you don’t know how to install the part with the instructions given you can contact me at
[email protected] I check it everyday and I will help you with anything you need.
Most of the parts we make use the stock bolts and screws any parts we make that do need bolts or any other part we will provide it for you.
Cold Air Intake Hydro Lock Plate
Front Underbrace Bar
Brake Booster Brace
