First thing I want to do is the exhaust. I was wondering is a custom mandrel bent exhaust is best or would going with stillen be better. Help a brother out!!
K&N filters in modified boxes and HPS silicone intake tubes.AceDuce wrote: ↑Mon Sep 18, 2017 3:41 amTHANK YOU FELLAS! I will get my local shop to delete the secondary cats, put in an x pipe and go straight out to some new mufflers. I'm too pumped for this. I'll look into getting a tune as well to unleash the full potential. Do you guys have a cold air intake and just k&n filters or a different set up?
I run the AEM Dryflow drop in's...developed in collaboration with K&N, without the oil. I drilled a series of holes in my stock filter boxes to help draw fresh air like a CAI as well as through the front grill. I also replaced the stock intake tubes with HPS silicone smooth bore tubes.AceDuce wrote: ↑Mon Sep 18, 2017 3:41 amTHANK YOU FELLAS! I will get my local shop to delete the secondary cats, put in an x pipe and go straight out to some new mufflers. I'm too pumped for this. I'll look into getting a tune as well to unleash the full potential. Do you guys have a cold air intake and just k&n filters or a different set up?
