96_S14_SE »
https://forums.nicoclub.com/96-s14-se-u2649.html
Fri Mar 28, 2003 2:41 pm
What the **** are you talking about? Its home made but no where near discracefull ghetto. You cant see the funnel as its black, the splash guards are on hiding the piping, and what else are you going to stuff a 7" dia. JWT pop charger into?
Its also the only S14 "TRUELY SEALED" functional ram air intake I have ever seen.. The 8" canister is professionally grafted into the 3" down tube via fiberglass and all solid internal edges have been smoothed for beter flow. The opening of the 3" down tube has also been shaved from 1/4" wall to 1/16" wall at the opening over a span of 3". Then the metal elbow has beenform fitted to the opening to eliminate turbulence again.
The 1/4" back cap is glassed on to the 8" tube as well as the epoxy then silicone sealants both blew off from the pressure it will contain at 80+ mph. Before it was 100% sealed I tested it to find 0 vaccume at speed on my NA motor.
The front 1/4" cap is sandwhiched between the jwt venturi filter base and the maf, with the hole exact. It utilizes 3 wing nuts, and bolts to hold it on, and has a 1/4" thick neoprene rubber gasket sealing it on.
Its so ghetto that it has lasted 2.5 years as well, and makes a very noticeable differnce in performance.
If I had my extra tank of argon, I drafted up an all aluminum one but I suppose that would be discracefull as well... Come out to OSW or better yet sebring in 2 weeks and have a go through the cones against my ghetto 240...
