1- I already have a custom built sub woofer enclosure in the trunk of my 2012 Altima. Will this still be fitted properly for the '14, or will I be looking for another one?
2- With a new head unit (along with a steering wheel adapter kit), have any of you got ALL of the steering wheel buttons to be programmed correctly? Specifically, I'm curious to know if the answer and hang up buttons can be programmed (A.K.A. "on hook" & "off hook"). In my 2012, my installer tried twice to get these buttons to work, but couldn't get them to go. The volume & skip tracks work great, but not these two (yes, the head unit supports these functions, as does the AXXESS adapter). Also, what steering wheel adapters do you guys use? I want to avoid any lag or other complications.
3- I will probably install new door & deck lid speakers. Any tips or things to avoid (speaker size, needed spacers, etc.)?
4- I am interested in doing remote start. I know things can get a little dicey with the "intelligent key", but I did some research and found that the CAN-sl2 bypass works well. Is this still the case for the 2013 / 2014 model?
5- With the new head unit, I would like to do an aftermarket backup camera. Can I use the OEM camera mount for this? On the trunk there appears to be a trim piece, on the bottom of the chrome plate near the trunk release button (on the "S" model), where the camera is normally located on the "SV" model (which has a OEM camera). Has anyone done this, or is there a better, cleaner looking way?
6- Where is the best place to hide a 5 channel amp?
Thanks guys, I look forward to your insight!
