Cusco Strut Tower Braces
matt0941
Car: Counter-Strike, Cars, Girls (in that order)
Many people consider Cusco when selecting Strut Tower Braces for their 240SX's. The following is a list of Strut Tower Braces made for the 240 by Cusco to clear up some confusion I have seen recently, good luck on your decision whether it be Cusco or not; remember, you don't have to select between these - they are just some amongst many.
TYPE OS Material: Light weight aluminum (shaft), Blue painted steel (plate)Style: Oval ShaftFitment: -S13: Front/RearFitment: -S14: Front/Rear
TYPE ALC OS Material: Aluminum + Carbon (shaft)Style: Oval ShaftFitment: -S13: Front OnlyFitment: -S14: Front Only
TYPE AS Material: Light weight aluminum (shaft), Blue painted steel (plate)Style: Circular ShaftFitment: -S13: Front/RearFitment: -S14: Front/Rear
TYPE 40D Material: Aluminum (shaft), Titan color painted steel (plate)Style: 'D' shape sectionFitment: -S13: Front OnlyFitment: -S14: Front Only
TYPE CB Material : Carbon (shaft), Aluminum in titan color (bracket & plate)Style: Circular ShaftFitment: -S13: Rear OnlyFitment: -S14: Rear Only
TYPE MT Material: ChromeStyle: Steel twin pipeFitment: -S13: Front/RearFitment: -S14: Front Only
I will edit in any changes if you reply to this thread by stating a problem/error that you see. This is intended for factual purposes so please, correct any mistakes that you see.
Thanks to http://www.japanparts.com and forum member 'ruf' for pictures and information.
-Matt
matt0941
Sorry I am not that familiar with Vbulletin, can anyone tell me how can I turn an image link into an actual picture on the thread?
Bud
I want the carbon fiber rear!Anyone know the torque specs for the front strut tower bolts?
Exar-Kun
Car: 2005 350Z
check the 240sx.org FAQ, and Im going to copy that into the FAQ man...good digging up on that info, Im sure people wanted to know about that other than you :)-chet
Bud
It mentioned replacing the bolts, but no specs.....
friskme
Thanks for the info matt... but iirc some of them (if not all) are not adjustable, and the adjustable ones will be pricey...this is why i will probably be going with whitelines. correct me if im wrong guys!
Exar-Kun
Car: 2005 350Z
uhh....adjustable STRUT bars? I think your confusing them with SWAY bars.-chet
EnzoRWD
Car: 1997 Volvo 850 T5
woah, you forgot the 3-pt rear add-on. thats the only reason im paying an arm and a leg for cusco bars, is to be able to fit the rear triangle-Enzo
