noodl35 »
https://forums.nicoclub.com/noodl35-u11553.html
Wed Feb 01, 2006 9:18 pm
So I just installed my fairly new JDM Cusco Zero-2's on the s14. I was dumb and forgot to tighten all the camber plate nuts that surround the adjust knob, not the shock tower nuts. Anyways, I put the coilovers on and when I'm driving I start to hear squeaking as I drive over bumps. Go back home and realized the nuts weren't tightened down all the way. So I tight the driver side rear coilover all the way down. Problem is the 2 front coilovers and the rear passenger coilover, the nut won't tighten all the way down because it starts to move the whole shaft & spring when I tighten. I even tried my airgun, but to no avail. I ended up taking the coilovers out and greasing them up just to make sure, but nope the squeek is still there but not on the driver side rear coilover (the one nut thats tightened down). Do you guys think this could be the problem to the squeaking noise? I may have to go to my friends shop who has a bigger compression and gun to see if I can tight all 3 nuts down TIGHT. Sorry for the long post but the sound is killing me.
