current project taking up space in my driveway (do people even use 56k anymore?)
Carl H
Friends car that we swapped the engine into...was actualy one of my cars at one point or another.Poor ka was on its last legs and it needed some help.info on the swap:r34 neo rb25detfmic w/ piping done by memodified r32 gtspec exhaustfull harness conversion including shortened harnesse&e motorsports mount kit (boooo...trans mount needed some 'massaging)tomei fuel pump
not complete yet as there are a few bugs to iron out like all 6 coils being bad and a bad ignition switch.
my poor crowded garage...anyone want a jag v8? has low compression on 7 of the 8 cylinders. woo!
Shocker
Car: 89 240sxHB rb26/30
cute, sucks about the coils.
god that plastic engine cover is hideous, take it off lol.
uber95
Car: S14
Shocker wrote:god that plastic engine cover is hideous, take it off lol.
But that's what makes it neo-licious!!!
craz4240
Car: 1995 240sx w/rb20det
See you were up to more then the jag swap hehehe Hopefully this went a little better man,i think the plastic cover looks good I'd leave it...
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Carl H wrote:My poor crowded garage...anyone want a jag v8? has low compression on 7 of the 8 cylinders. woo!
No, not really. But I _AM_ interested in that _lovely_ hot-air-balloon trashcan! I must have it!
So your spring break was quite eventful, yet not as much fun as you would have liked? Sorry to hear that
What does the engine look like without the plastic cover? Similar to a R33 RB25? I guess I would leave it just to make it 'neo-licious!'
Carl H
what would be nice is if i could figure out why the car isnt sparking...the irrtating thing is that it has power ground and signal at the coil plugs but no fire even on two different ecus and different coils.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
neo-licious!
Carl H
well we finished up this swap this past week, and ironed out all the little issues here and there.all i have to say is that this car rips absolute *** for a stock setup with basic mods, at 10psi the top end of this car is phenominal even on stock cams and pulls to the 7.5k redline like no other.a very impressive swap and definately worth the money, and we got this swap done for ~4.5k total...not too shabby for a bpu'ed neo.dyno sheet today hopefully, going to guess high 200's low 3's on 10psi.
l0nestar
2004 Toyota Altezza
Congrats man! Glad to hear it is fully out of your driveway! Can't wait to see the sheet! What all 'basic mods' are done to it? (other than what are seen - FMIC, cone filter, exhaust)
Carl H
i'll try to get the sheet up later but car made 250whp@6psi on the stock turbo (spikes to 8 but then drops)...so its got quite a bit of potential.the basic mods are all that you can see...cept for the 20 actuator swap, i think the reason we're seeing such poor boost response out of a known 10psi actuator is because of the factory cast turbo elbow.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
see man i told ya them NEO's are a force to be reckoned with...lol...glad you got them there bugs worked out.....now all ya got to do is tog et it up to where mine is at mod wise and both of ya willbe smiling from ear to ear...my car is simply amazing...this is my first RB ive ever owned but its not the first ive been around nor driven...but the way mine is setup its super smooth, tons of power and freaking blast to drive ..love it love it love it...hehe
bumblebtuna
Car: rb25/26 2fotay
so close, so close. neo ftw
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Ok since theres a bunch of neo'ers in this thread i want to ask a few questions:
-Is there a Power FC for the neo? If not what other plug and play standalones are there? What are you guys running on your neos
-This is a question for you Carl H: I understand the rb25det ECU will not accept a rom tune at all. Do you know if the neo ECU is any different?
-What can one do if their swap doesnt come with a MAF? The neo will only accept a neo MAF and theyre super rare arent they?
Edit: Also heres a really noobish question. Im assuming that IC piping is aluminum right? did you tig or mig it? Im kinda interested in learning how to weld my own crap.
Modified by ST240 at 6:01 AM 4/14/2008
S14-NEO
yes the Power FC was made for the NEO and i am running one, and i am also running a Z32 MAF as well...my setup didnt come with either the MAF or the ECU so i improvised and went another route.
driftjunke
Hey Carl, that was a mount kit of ours? Who did you get it from?
E
Carl H
bought it from a member on here a year or so ago when he was parting out his parts setup...was local to the agusta area and had a seafoam coupe.
Impulse_240
Car: 1989 Nissan 240sx
hey carl, do you know where your friend got his neo engine from?
RBvipVert
Carl,
Where did you get the intercooler? Can you provide me measurements?
Thanks!
blurrbosi
Car: 240's
I hate the plastic cover. But I bet she pulls hard at topend in a s13. Stock pull on my 25 felt too good to be true, I thought it definatly had aftermarket cams in it since it pulls twice as hard a high rpms... You can get more power out of it with the stock actuator probably. Boost falling off at that low of a level is a little weird...
driftjunke
I've only done 2 Seafoam green 240's, KA-T and SR, probably was Top Hats mounts.
Carl H
nope they were definately your mounts as it came in a box that was marked e&e motorsports.powdercoated a gunmetal swirl.
Neejay
RBvipVert wrote:Carl,
Thanks!
+1 - What kind of intercooler is that?
EDIT: I found it, but what are the dimensions of that one? Did you have to cut anything?
Modified by Neejay at 3:54 PM 5/11/2008
neonbomb
so that's what chris's car looks like lol
Carl H
only cutting that was required was that of the front lip...
Carl H
intercooler is the ebizzle special, cheap and very effective...definately reccomend this route over the 30' of pipework normally required.a few more pics of the finished product:
Coolwhip
Vendor
looks good Carl
DeclareYrWar
looks good man, is that piping aluminum? if so i need to talk to you about some welding when we do my ecu and such
DriftX
Car: '89 240sx
very clean carl.. digging the fmic setup. I'm getting ready to make a 3in custom dump for the stock rb20/rb25 turbo.. if you like I could take down some measurements if you want to make one later on?
mello88
Car: s13
Looks clean. I like the puller fan setup, what fans are they? I have a similar FMIC setup for my 20, can't wait to get it going..
DJButton
Car: 2010 Nissan 240sx
Looks nice all back together and such.
