amarokorg »
https://forums.nicoclub.com/amarokorg-u5424.html
Sun May 06, 2007 6:57 pm
Considering selling my '92 Vert. Yeah, I know, I just got the darned thing. (Ok, a little over a year ago..)
Anyway, since I've moved and started a new job, I'm traveling a lot and really don't have the chance to drive it. It's shame to let it st.
Since I've had it, I had a few issues, but believe that I've got them all worked out.
Had an overheating problem (never let it get hot to the point of damaging anything serious) that eventually turned out to be a combination of bad radiator (cracked end tank) and failing water pump. One of the casualties of the heat was the spacers on the injectors, so all four injectors were replaced with matched/balanced stock-rate units from DeatschWerks. Radiator was replaced with a stock-like aftermarket unit with metal end tanks, water pump, thermostat, radiator cap are all new. Factory belt-driven and electric A/C fans both replaced with dual-Altima setup.
Compression test shows all cylinders to be a bit low, but not unexpected for a motor with 160k on it. Adding a little oil to each cylinder brings the compression up to spec - (i.e. rings are worn, not blown headgasket or valve trouble).
Front end wobble fixed with new T/C rods and bushings.
New tires, Kumho daily-driver type. Nothing fancy.
S14 seats, good-to-fair condition - about what you'd expect in a '95-'96 daily driver.
New carpet (not installed), comes with.
New battery.
Cheap ("Dual" brand) CD/MP3 stereo with XM Radio.
Top is in good shape, some discoloration along where the rails ride, window has some fogging (but still pretty good visibility).
Minor body dings here and there, nothing major. One spot of rust coming through near rear wheel well.
Car has been painted at some point, I'm assuming that it was involved in some minor collision. I really don't know the history of it. The car drives straight, though.
Looking for advice on what you guys think it might be worth. Located in Dallas / Fort Worth area of Texas.
Ideas?
Thanks guys!
- Dave
Modified by amarokorg at 3:48 PM 10/7/2007
