Curious on how much HP ill be able to make
Ronie300zx
Car: Nissan 300zx red N/A
Currently i have a 93 nissan 300zx NA and ive been working on it for quite a while its at the body shop getting painted. I have a TT engine im working on the side that im putting 550cc injectors, basic engine rebuild (wiseco/eagle) 88mm, ARP head studs, and of course new timing belt and ect. I have the block and heads at the machine shop getting cleaned up so im waiting on that so i could get ready to put everything together. im going to run godspeed side mount intercoolers to test them out, im just trying to figure out how much would hp i would be able to push ?
centralcoaster33
Car: 1997 Nissan 240SX #5
For those interested in speculating, perhaps you can mention your ECU plans. The computer and it's program matter for your HP question. Hopefully you'll have it tuned and dyno'd at the same time for optimal results. A basic rebuild and factory ECU = OEM power. Changes to bore, stroke (compression), cams, injectors, exhaust, intake, port matching, ECU tune, etcetera should have an effect. What are your changes exactly (before and after)?
Ronie300zx
ohh im sorry i forgot to mention it, yeahh im going to get the ECU tuned and dyno'd over here in Tampa by Z fever most likely
Ronie300zx
Okay right now im running NA but i have a TT engine im working on, the condition it was in before or anything i wouldnt know becasue i bought it from sombody in Bradenton for $300, cant beat that lol It came with megan racing headers already on and the EGR delete and little other stuff. When i took it apart it didnt really seem so bad, only really thing i seen from what i noticed that it was missing a Main bearing.. Pretty weird but it is what it is now im trying to build it and see what i can do once i do my swap
