deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Feb 27, 2005 8:55 pm
jp86, your thinking is correct it can be done.
I forgot the guys screen name, but he was the person that recently swapped the de cylinder head on his e block in a stanza. He was able to use the obd1 altima de distributor with the sohc stanza ecu. The obd1 240sx de distributor should do the same, although im not sure about plug working.
you can delete both of the vacuum units that sit at the rear of the head on sohc and other emission tidbits, everything else should basically swap over. You know well enough youll have to change some plugs, and like IveBeenBad mentioned youll need the sohc maf. Injectors are high impedence and will work with sohc ecu. Not sure about tps sensor being compatible, if not there is most likely a simple way to make things work. You will also lose all knock sensor function, its a primitive listening system anyways.
You can always easily tune the sohc ecu to provide the dohc exactly what it needs as far as timing/fuel map. Should be very little change if any to make it run like stock.
