Curious about ECU numbers
skillzilla
I searched high and low, and only came up with one thing:
RB20 ecu's have "23" on the side. All the ones Ive seen have, even from a Cefiro.
Question is, mine says "65" on it, and for some reason Im throwing code 54, "Auto Signal to ECU". Perhaps my ECU is from an auto-transmission RB20? Do they cross over with no problems down the road? Im thinking mine was converted to 5-speed at one point, as its from a Cefiro, and I believe they all come Auto from Nissan.
Anyone have a "65" ecu or information on them?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
mine says 22 on it.
skillzilla
WHAT??!!! 22??!!!
That totally ruins my theory....
:D
JonPowell
Car: Cars, Music, My family
what is the actual PART NUMBER-----
XXXXX-XXXXX
Then I can cross that number to what chassis it would have come from.
skillzilla
Its 23710-73L10
thanks homie.
JonPowell
A31 (Cefiro) 9/88 - 8/90 RB20DET Automatic transmission
skillzilla
I knew it, thanks Jon.
Sil240
Car: Nissan S13 "The One Cam Wonder"
My ecu has a 22 on it as well
JonPowell
I dont think the 22 really means anything, maybe a quality control number or something.
Yellow4g63
2223710 04u12MEC - r127 1 0800
Numbers I got off the ecu cover. What is it from?
JonPowell
R32 9/89-8/91 Hicas 2WD RB20DET AUTO TRANS
Yellow4g63
JonPowell wrote:R32 9/89-8/91 Hicas 2WD RB20DET AUTO TRANS
I knew it was from an auto car! thanks. BTW anyone hit the speed cut with the swap?
JonPowell
if you dont wire the speedo to the ECU you will NEVER hit speed cut. Just wire the speedo to the gauges.
skillzilla
so the auto ecu will run a manual I take it. Thats good news for me, since, well, thats what I got.
Thanks again Jon.
JonPowell
I had an auto ECU on my RB25DET and it ran fine also...
FAST-DATSUN
Jon can you PM me???????????????
Yellow4g63
JonPowell wrote:if you dont wire the speedo to the ECU you will NEVER hit speed cut. Just wire the speedo to the gauges.
Will do that.
