goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Sat May 17, 2008 7:31 am
While my 90Q is up on jack stands waiting for the correct rear strut bushings to arrive I thought I would tackle what I consider to be the most serious flaw in the design of the 90-93 Q's..... no cupholders. I can understand the mistake with the chain guides, and the weak sunroof switch, and even the bad trannys, but how did the Infiniti design engineers forget the most essential of conveniences- cupholders for the morning commute?
I've had a few pieces of good quality redwood burl stored in my garage for the past 30+ years (left over from my hippie days roaming the Mendocino coast trying to find myself) and had another brainstorm (they're rare nowadays) that put a couple of them to good use.
I started with two pieces of burl, both about 1000-2000 years old BTW, one almost black in color but very dense and difficult to cut, and another larger piece with the normal reddish color and very desirable birdseye woodgrain pattern. I cut them to size on my table saw and took them to the carpenter shop at work to drill a 2 3/4" hole and finish sand on a commercial table belt sander. After 5 or 6 coats of verathane (sp?) I got some scrap 1/8" thick lead sheets (from the x-ray shop at work) and bonded them with clear RTV adhesive (out of date from the assembly area at work) to the bottom of the two thinner pieces. The darker piece was heavy enough to stand on its own without extra weight. Finished them off by gluing a piece of tool box drawer liner to the lead so it wouldn't slide around in the center console.
The picture doesn't do them justice but the birdseye pattern in the burl pieces is very nice. I've been up to the Humboldt redwoods recently and there's very little birdseye burl available any more. All the hippies made coffee tables out of the best, largest pieces and clocks out of the smaller pieces.
Installed in the Q. I like the looks of the darker piece also and may use it instead. To me it looks better with the black interior. This one, with the lead glued to the bottom, weighs about 2.5 lbs and is plenty to keep a medium-sized cup, can or bottle from tipping over. They're all sealed in verathane and can be rinsed off under the tap when they get dirty.
You don't need to use redwood burl and lead sheeting to make a cupholder. The same can be accomplished with a short piece of 4 X 6, hole saw and a sander.
