95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Fri Jan 19, 2007 8:20 am
remove the cup holder, and everything should be visible once removed, to remove it:
open the cover of the centre glove box, you will see a black trim piece that is between that box and cup holder assy. , pry it out carefully, there are two plastic clamps that are part of the trim, make sure you dont break them. then you will have access to the 2 philips screws holding the cup holder, the cup holder should come out easily afterwards
once that is done, you will see the mechanism (the button will stay in the console), inspect it, and fix and return everything in revese order, i hope this helps, good luck
