Cultch Problems
jsando2
Car: 1993 Nissan 240SX Hatchback
2009 Nissan Murano SL
I took my car to the shop cause my slave cylinder was leaking already. Anyway I took it to the shop and replace it with a new one, then try to bleed it with another person and for my surprise I didn't get any presure it stayed all the way down also it was loose didnt get any grab on it sometimes a little but little presure and then boom nothing... so then I change my master cylinder and nothing same thing. Im changing the hose tomorrow to see... Is there's anything else around that i should be looking for to fix this problem? The car was working when i got to the shop so I dont understand y I aint getting no grip or presure on it...The fork is a little soft to the point that i can push it with my hands...Is that OK? The car got me to the shop...I hope is not the whole thing again, but like i said it was working perfectly until I saw the leak and changed the slave cylinder...Is kind of weird any opinion will be appreciated...Que viva los 240sx/////
Modified by jsando2 at 12:29 AM 8/17/2006
Modified by jsando2 at 12:31 AM 8/17/2006
x240xdrifter
Car: 1991 Nissan 240sx
you neeed to bypass or take out the dampener box and it will bleed in secondsdid it to mine and loved it
http://www.zeroyon.com/index/content/view/32/47/
jsando2
I see. Well I'm not getting a High Peformance clutch for now , I will do this, Question...Is there's any damage to any other part of the hydraulic system once you bypasss this box? How about if my fork is a little soft coming out of the trammy? will it be that my pressure plate is gonne? Anyway I did open the valve of the box and fluid came out constanly, Even if you bleed the box system it would still do the same thing??? I just dont want to get rid of it right away you know what I'm saying? Anyway thanks men...any other advise will be appreciated
jsando2
I'll be getting h.p. clutch soon...I'll let you know how it went with the bypass...Thanks...
jsando2
I bypass the box but theres a problem the fitting on the line coming from the master cylinder does not fit properly and it leaks so that application dont work on my car...I order the hose thats the last thing im gonna do///talk to you later
