Oh, my bad! BTW, would anyone happen to know the offset of the Cube's wheels? I think +35mm will fit my Sentra if it's 16" (Like the wheels found on the Krom) or maybe +40. All I know is that 5mm makes a HUGE difference.indomiekid1 wrote:check the offset too.
That's what I was thinking today when I had a chance to park next to a Krom. Of course, the Krom is lowered but I realized that I most likely will need to go with smaller sidewalls if I were to run the Krom's wheels (which is HIGHLY unlikely). Based on what I had seen with the Krom, the widths are reasonable enough that it shouldn't compromise my turn radius (I hope!), but you're definitely are right about the sidewalls; the lower it is, the less of a headache I'll have in the long run.CubeRich wrote:Yes... the cube wheels are 4x114.3... you'll prolly need some lower profile tires than what comes with the cube though.
Hey thanks for the help. In fact that's almost exactly what I had intended on doing to my Sentra.ChopsQube wrote:I had a '96 200SX SE-R that I slapped some Fittipaldi Polaris 17x7 wheels with 205/40-17 Yokohama rubber on with no problems at all, and I was lowered 1.5" at all four corners if that helps at all... I really miss that car.
Thanks for the info. +42 is at the very limit of my offset range, but should be enough to work (hopefully) with no problems. About the wheels: are those the Krom wheels or the 4-spoke splits that came of your cube? Also, good luck with the "hellaflush" look. If the roads where you live are anything like on Oahu (ask any members from HI, they'll tell you!), you should consider 'bags, especially if it's a daily. (Hopefully a direct-fit kit is available by now.) Sure, it costs more, but running a static drop will cost you a lot more when you always have to take it to the shop because of underside damage.meisrandy1 wrote:the stock offset for the cube is +42 and its a 6in wide wheel. something thats like 7in wide with a 30 offset is pretty safe. I just got some wheels for my cube its 18x8.5 and 18x9.5 +32 the rear and front comes out no more then .5in but im planning on camber. trying to make it hella flush
