Post by chuxk79 » https://forums.nicoclub.com/chuxk79-u162036.html Wed Jun 02, 2010 4:45 pm
Post by CubeRich » https://forums.nicoclub.com/cuberich-u155063.html Wed Jun 02, 2010 6:59 pm
I can't say specifically that I've noticed it in mine... but I've noticed it in virtually every car I've ever owned... if you haven't noticed it before, it's probably because you weren't paying enough attention... when you release the gas, you are changing the load on the drivetrain... you'll also notice it when you push the clutch to the floor.chuxk79 wrote:I just bought an 2010 base cube w/6speed. I have noticed that in 4th and 5th gear
when you back off the gas the shifter moves a little.The shop forman at one of the local dealers said that it's normal as on the versas,anyone else notice this on your car.
Thanks chuxk
Post by chuxk79 » https://forums.nicoclub.com/chuxk79-u162036.html Wed Jun 02, 2010 8:13 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
