ct26 elbo???
24DSXY1
Car: 1991 NISSAN 240SX
This ct26 has an elbow on it but I need one that goes down, not to the side. It has almost the same shape as the 5 bolt outlet on a t25/t28, but it only has 4 bolts. Where can I get an elbo for this? Sorry, no pics.
Chezedik
Car: 1991 Nissan 240sx
Talk to JGS, I know they have a mani flange for that, they may have a dump flange.
KATwo40
Car: 1993 240sx KA-T
You could get one from an MR2 turbo car (3sgte).
24DSXY1
It already has the stock elbow which goes to the side but does the mr2 elbow go downwards? I'm gonna use a bottom mount manifold.
KATwo40
Yes, it goes down.
24DSXY1
Alright thanks, now I just have to find a turbo mr that's down.
smokey240sx
I have a 3sgte ct26 elbow. shoot me a offer at [email protected]
24DSXY1
What size flange does the ct26 turbo use, a T2 or T3?
Chezedik
I would doubt very much that it is a T3 or T2. In fact looking at the picture it looks more like a T3 from a Volvo, but not quite. It is just it's own flange, you can get it from JGS.
http://cgi.ebay.com/ebaymotors...wItem
Chezedik
smokey240sx
For some reason I have two ct26 with elbow. This is the dirty one
This is the one has High temp aluminum paint on it.
24DSXY1
Looks like my hopes for using the ct26 turbo are lost because the only manifolds available have t2 and t3 flanges and I'm not going to spend more for an adaptor plate than I will for the turbo.
Maybe I'll try the godspeed kit on ebay or put together a gt28rs kit myself. Thanks everyone for trying to help me with this project!
Chezedik
I am telling you that JGS makes a mani kit for the CT26, I have said it three times.
Here is the linkhttp://www.jgstools.com/turbo/index2.html
They have a drop down menu that lists the CT26, and you can locate it however you want.
And just to show that I am willing to do all of the work:
Outlet Flange -http://www.bicperformance.com/products. ... w_cart.asp
I could keep looking but won't. This is what you will need to craft your pipes. As far as oil lines, you should be able to find fittings. I personally made an oil line for one using hydraulic hose and eaton fittings while I was at NAPA for a guy.
Unless you want a kit, this should provide you with what you need. But if you prefer, there are a ton of elbows for this turbo from SSAC.
Good Luck!
