huguetpj »
https://forums.nicoclub.com/huguetpj-u637.html
Sat Aug 27, 2005 12:09 pm
Ok, guys. I promised pics and boy do I have pics. First I'm going to put the facts and then I'll put what my mechanic thinks and what I think happened. Take into consideration I had been running 9PSI for a long time. I had run 14PSI for like 2 months and failure occured when trying to up the boost to 18PSI. I was still running the 9PSI maps I had setup on the dyno caused I forgot to include more fuel for protection... yes you can hit me for that.
First of all, once we took out the engine we saw holes on both sides of the block on rods #2 and #4.
There is also a hole on the right side of rod #1, which actually removed the alternator base from the block so the alternator was hanging.
The left side does not look good either.
My main concern was the head. So I was real anxious to get it off. At first site, when we removed the valve cover, it looked ok. No signs of problems.
The timing kit was also ok. Meaning that at least the crank and cams kept turning in sync. Lucky me since I had them replaced brand new from my last rebuild.
Once we got the head off first thing we looked at was the pistons. Pistons 1 through 3 looked ok. Piston #4 looked like it contacted water.
Pistons #1 & 2
Pistons #3 & 4
Under further inspection, the gasket had given way between cylinder #4 and a water passage causing water to get into the cylinder. None the less, the car did not smoke nor did it consume water before that night, cause I check the radiator level just before going out for testing.
So now onto the head. When looking at the face of the head you can see all valves look ok but cylinder #4 looks a bit too white, meaning possible lean conditions. Also, under further inspection we saw contact @ pistons #2. The same evidence can be seen on the piston:
We are going to test all the valves later to see if they are still sealing.
Some of the miscelaneous bits and pieces found. On the oil pan you can see a piece of the main bearing cap (center of pic) and the top part of the rod #2 end.
The bottom part of the rod or rod cap #2 was found on the highway...
Now from the oil pan pics you can see water in the oil. But looking at the main bearings I don't see any evidence of water induced problems:
Main bearings #1 & 2:
Main bearing #3:
Main bearing #4:
Ok. so rods #1 and #3 came out clean. Rod end #4 was still on the crank and it could still be moved easily by hand so it was not stuck to the crank. Rod #2... well as I said before the rod cap was found on the highway. The top part of the rod end was found in the oil pan. And the crank looked hitted or impacted on rod bearing #2.
Rod #1, 3 looks the same:
Rod end #4:
Rod bearing #2:
And wrapping up... this is what pistons #2 and #4 looked like. It does not need to be said that the rod was almost welded into the wrist pin and could not be moved by hand.
Now onto the subjective part of this post. My mechanic believes that the water entering cylinder #4 caused the rod to fail. I on the other hand believe that if this was so then the rod end should be stuck to the crank or something. The water should have caused bearing failure and this caused rod failure? Am I way off? Also, as I said, the car was not consuming water before that night so maybe the gasket failed when I was testing @ 16PSI with ****ty fuel maps (rookie mistake). I still believe that me not adjusting the fuel maps caused detonation. Maybe this caused the rod bolts on rod #2 or the rod itself to fail and pieces of rod #2 caused rod #4 to break in two. My mechanic did say the other bolts looked worned out. By the way, this were stock rods on stock bolts.
What do you engine gurus think?
