I
S13FX wrote:OK I research cryogenic treatment a while ago, basicly a simple answer to question is. Particles in steel are under pressure, thats why they are bound to break apart when you put more stress on them. So as many of you have guessed by CRYOgenic, they cool down the part down to I think -700kelvins, that literly takes all the particles in the objects and relaxes them.
I have to be honost...i don't quite trust your input...as 0Kelvin is actually -273.15*C or -459.67*F...so the -700Kelvin isn't really a POSSIBLE numer...at 0Kelvin all matter stops moving...its also known as absolute zero...
I do think that youa re on the right track tho.
There is alot of theory behind cryogenic freezing, and all that good whoohaa...but information as to how it works exactly is very detailed, and answer this simple can't really get it all across...
But yes, in your average stainless steel, it will increase life and durability of parts a minimum of 50%...and there isn't only streingth increase...but because there is less flex, and more rigidity in the metals, performance is increased, because effeciency is.
Carefull tho, thinking about all the technical stuff behind it, cryo'ing a valve train, can change the entire resonant frequency. But i haven't done much research to decipher whether it would be better or worse.
