96Qowner »
https://forums.nicoclub.com/96qowner-u19561.html
Sat Oct 13, 2007 7:02 am
You can't really exercise rpms effectively cruising on the highway. It would carbon-up less if so much of your driving wasn't at steady speed.
What you can do is find yourself a can of BG 44K fuel system cleaner, put it in the tank and go romp on your car some. Floor it and let the motor wind up - it's fun! The only caution ... I would suggest not running the transmission through too many floored shifts - ease up around 6000 rpm and let the transmission shift. Romp as much as you can on that tankful, and then change the oil.
Do that before every oil change, and it will help a lot.
