NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Jun 10, 2005 2:13 pm
Its called an engine support and it does not raise the engine it mearly holds it in place while you lower the mounting point out from underneath it. The bar sits oneach strut tower and has a hook on it that you hook into you lift loop located at the front of the engine. This will suspend your engine while you remove the lower crossmeber a bit to allow the pan to slide out. What i do is once I have it hooked, I go down and remove the 2 nuts under the motor mounts holding it to the crossbar, Then I got back up top and use the nut on the hook to raise the engine a little to take its weight off the cross bar [this is important when trying to bolt up the cross member when going back together]. Then i slowly remove the bolts holding the crossbar to the car. I am trying to remember if I left the rack attached to the cross member or not, not sure but at that point you will figure out what needs to be down just by watching how the parts are moving with it. I think I did unbolt it since it was stressing the steering coloum shaft.
EDIT: You may be able to rent a engine support bar from a local rental yard.
