Crush Washers
ganondof
Car: 2010 Ebony 3.5SR
For those that do their own oil changes, where do you guys get your crush washer (if you change them). I know about http://www.courtesyparts.com, but $17.06 for shipping to Canada is a bit too much for 10 washers for $7.10. Is there anywhere else online that sell these for cheaper or any stores that carry them. so far i have checked at Canadian tire and they dont carry any. i havent checked the dealership yet but im guessing they are going to charge like $3 each. Any help would be great. Thanks
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
The dealership should have them for less than $1. If you are particularly friendly, they may just give them to you for free. If not, any auto parts store sells generic copper crush washers.
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
I have only used one and have never replaced it in almost 6 months, multiple changes later. No leaks. Its recommended, but not needed unless you feel it's going to leak :).
mrodrig2
It is needed, but just not necessarily at every change like they say. If you aren't trying to be He-Man your crush washers should last a while. However, most people and lube places aren't that careful and just crank it down so they recommend a conservative change interval.
ganondof
Went to the dealership, $2.25 each. not even a crush washer, just a regular copper washer.
telcoman
QR25DE wrote:I have only used one and have never replaced it in almost 6 months, multiple changes later. No leaks. Its recommended, but not needed unless you feel it's going to leak :).
I know it is recommended but I've done 38 oil changes on my G and never changed the crush washer.
After changing oil prior to remounting the fiberboard shroud I always start my vehicle and check for leaks at the drain plug and oil filter. Never had any leaks
Telcoman
jdeb101
Car: 2008 Altima Coupe 3.5SE
Nice avatar telcoman! BA BA BOOEY!!!
telcoman
jdeb101 wrote:Nice avatar telcoman! BA BA BOOEY!!!
He mentioned on today's show that there were only 55 left until his contract expires,
I don't know what I'm going to do if he leaves :ohno:
Telcoman :ohno:
BlackMetal
Car: 2009 Super Black Altima Coupe 2.5L 6spd
just picked up 10 from my local dealer. 10 dollars and change... I do change them with every oil service...
Throckmorton
Car: 2007 Altima
Here is what the Nissan Factory Service manual says about changing oil. I wonder what they know that we do not know?
I know that Nissan is not able to balance their corporate books by relying on the sale of crush washers. Could it be that they are attempting to prevent problems in the future with your drain pan leaking?
From the Nissan Altima Service Manual:
1. Position the vehicle so it is level on the hoist.
2. Warm up the engine and check for oil leaks from the engine.
3. Stop engine and wait for 10 minutes.
4. Remove the oil pan drain plug and oil filler cap.
5. Drain the engine oil.
6. Install the oil pan drain plug with a new washer and refill the engine with new engine oil.
Oil pan drain plug : 34.3 N·m (3.5 kg-m, 25 ft-lb)
CAUTION:
• Be sure to clean the oil pan drain plug and install with a new washer.
• The refill capacity depends on the oil temperature and drain time.
Not once but TWICE the crush washer was mentioned in this procedure. Coincidence or Conspiracy?
Not one but TWO major manufactures--Honda and Nissan-- say the exact same thing about crush washers. Coincidence or Conspiracy?
Here is Honda’s advice:
The crush washer does more than prevent a leak between your drain plug and oil pan. A crush washer is designed to be a one time 'use and throwaway' item. It is designed to 'crush', so you don't strip the threads on the oil pan, by over tightening the bolt. They are not designed to be reused, however as you have discovered, you can reuse them.
The new washer, purchased either at a Nissan dealer, Auto Zone, Advance Auto, Pep Boys, etc, is very cheap. I think I spent just a few dollars for a pack of them, and they will last me quite a while.
I know from experience about changing the washer. A few years back, I owned a 1986 Accord. I changed oil and filter every 3000 miles, never changing the drain bolt crush washer. After a few short years, I stripped the threads on the oil pan from over tightening the drain bolt.
I spent over $200.00 having a new oil pan installed. Now I have learned my lesson, and change the crush washer every time. What you do with your car is your choice.
QR25DE
200 for an oil pan installation? wow.. ripped. lol
