Crush Washer
tama48
Which way does the crush washer go on the oil pan drain bolt? I can't really tell by looking at the old smashed one. Like a bowl with rim against pan or like a bowl with rim against inside head of oil pan bolt?
Thanks
motoguy128
Car: 2007 Nissan Versa S - 6 Speed
I'd assume the best way is with the more flat or concave side goes against the bolt shoulder. The rounded or convex side goes against the oil pan surface. If you put it on the other way, I still doubt it would leak. I've changed oil 4 or 5 times bofore without ever changing the crush washer... and never had a leak. I typically change it every other time. Just be sure not to over torque it. 25-30ft-lbs is plenty.
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
The rim goes against the pan.
tama48
Thank you. That's the way I did it.
