Cruise Module Location???
Bwana
Car: Denali
Does anyone have a pic of the cruise control module for a '93 Q? I'm trying to find the thing to do some diagnostics but can't seem to lay my hands on it. Thanks.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ive had my fights with the cruise control, whats it doing.....
Its in the dash somewhere...
Bwana
Car: Denali
The light on the dash switch turns on but I get nothing after that, no cruise at all. My manual tells me that it's on the pass side under the dash but I had the glovebox out and the lower pass dash completely apart but couldn't find anything that I could positivly identify as the cruise module. Anyone ever found this thing? BTW, car does have TCS.
elwesso
2007 BMW M Coupe
In all honesty I think that its best if you go to the dealer, and they will use the consult to test each thing and it will tell you what thing is bad..... Will save a lot of time and unnecessary disassembly..!
Try the battery trick.. Unplug the battery for a few hours and plug it back in... That fixed mine!!!
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
I lost cruise once with good lights on the dash and it was the cable that runs from the solenoid near the master cylinder to the passenger side of the plenum. It had popped out of the bracket and was easily reattached.
