Cruise control with SR?
240_Keyy
Car: '90 240 Fastback
Hey all, I just thought of something yesterday while I was helping my friend out with his 5 lug conversion. I got to looking at his motor (he has an SR) and I noticed that there was no cruise control attached. I asked him about it and he said that the shop that did his swap couldn't figure out how to make it work. That isn't too suprising to me since they also forgot to bolt his motor to the mounts when they put it in...
Anyway, I was just wondering if I can retain cruise control when I do my SR swap. My friend said that of all the people he knows in austin with SR's in their car, none of them have cruise.
Any info would be much appreciated.
martin
Good question!
The answer is.. "I don't know", but it's something that I've looked at and will be attempting on my SR when the weather warms up a little.
I hope that it's just a matter of putting the original cruise from yoru KA onto the SR. You will need the throttle cable "thingy" (eccentric?) that cruise cable rides on and hooks to. This might require a longer throttle body shaft (ie. the one off your KA).
As far as I can tell the cruise is not controlled by the ECU, althought I could be wrong on that. If it is we're probably screwed. I think it's just controlled by the speed sensor, and vaccume.
I'd be interested to see what anyone else has to say.
-Martin.
SpeedRacer1
Car: 1990 240SX, G35
I thought CC was only for automatics. That might be one reason nobody has it.
240_Keyy
WTF?! Crapsky! I ought to just give up on this whole damned thing if I can't have cruise control.
And get me a real car, like a 1983 Cavalier.....
psyche!
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Quote »I thought CC was only for automatics. That might be one reason nobody has it.[/quote]
Looks like someone hasn't been on long long road trips with a 5 speed too often. Most 'modern' day 5 speeds have cruise as an option. My 97 SE and 89 were both 5 speeds which did indeed have cruise. Cruise is controlled under the hood through vacuum and air valves on the 240sx. On a 5 speed, it is also assisted by a brake switch, clutch switch, and a unit mounted in the kick panel along with the ECU.
240_Keyy
I was gonna say, my '90 KA 5spd has cruise, I was just wondering if there was a way to retain it.
MojoMan
Car: working on cars and women
If you have the original cc on your car you can retain it . I do. I only use for raod trips like when Im doint light speed. Haven't done that in a while. hehehe. Just put my motor back in.
sr20det
Car: Drifting, draging, silvia projects
well, i think to be able to have cc u need cc in the car in the first place. after u swap with sr just get like a s14 blacktop sr20det throttle with cc and hook up your cc line to it then it should work. i think...
SpeedRacer1
Yeah my car is old and ghetto.
Ace
Car: S14
Well Heavy Throttle wired my harness to retain the cc. The problem is the throttle. I need to rig something up. I'll worry about that later though.
