StevenRogers wrote:nope you got it.
im almost sure i threw it into tiptronic mode, so that i could keep it in 5th gear (i thought originally it was going back and forth between 4th to 5th gear).
i have never experienced this in any other car ive drove, but i cant remember if ive ever cruised in the mountains either.
what bothers me is that it did not only throttle blip when inclining, when declining and i believe it did a little bit on the short flat straight aways. but all in the same time frame of about 20- 30 min. then gone.
but like ken in az referred to in the manual, cruise probably is not to be used in the mountains. i need to look at what else is in that manual!
Did you try it with the conventional cruise control engaged yet? This type of behavior could be signs that your lock up solenoid is going out in the transmission or some type of CAN communication error hapening while in cruise mode.
And yes, you can engage it into manual mode then engage cruise. That is how I normally do it but I'm not sure if it disengages cruise when you go from auto mode and switch to manual while the cruise has already been engaged. I'll have to try it.
Steven, try the above and see if it does it, I would also recomend to videotape it and take it to the dealer the next time you are in and they should be able to tell you if it is normal operation or not. I know when I first drove my car in the mountains the cruise control was acting very strangley, but that was too long ago to remember the specifics.
Good Luck
