slow s13 »
https://forums.nicoclub.com/slow-s13-u2766.html
Tue Dec 14, 2004 12:46 pm
first turn the cruise on by hitting the button on the left of the steering wheel, it should have a little green light on it, if not the bulb is burnt out or there is a problem. Then use the set button on the wheel to set it, if your car is a manual make shure your cluch is up all the way, you may have to pull it up with your foot to get the final bit of slack to make contact with the swich thats on the cluch pedal, one way to check that is to get your head down where the cluch pedal is and press and slowly release the cluch and see if it returns all the way and presses the swich down. I see your light is on so another thing I would do is check the vacuum hoses on the cruise controll actuator under the hood.
