Cruise Control!?!?!?!?!?
All things Altima Coupe.
BzOaY
Car: 2008 Altima Coupe
So this morning i got onto the interstate doing 75 and i went to go hit the cruise on (worked) then i went to go hit SET and it didnt do anything...well kinda...all it did was blink and it never actually worked...so i shut the cruise off thinking i could try it again, but when i turned it back on the SET was still blinking?????? any ideas
AlexM.
Car: 2010 Nissan Altima Coupe 2.5 Super Black
Never had my SET blink before.
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
Power off car, go try it again. If it still doesn't work your cruise control may be busted. :/
BzOaY
im sure in a couple days it will fix it self...seems to happen with my car lately. Few weeks ago my check engine light was on, code said it was running too lean. i cleared the code and it never came back on and car was running fine. Then just last week check engine light on again checked it said it wasnt idling right but it was running just fine i forgot to clear the code but the next day it didnt come one and hasnt came on since and now this...i think my car is haunted or something
BzOaY
Thanks, so yesterday my check engine light came on again...ran the code it was the idler again...cleared the code and my cruise worked...? :confused: :confused: :confused:
the guy at the store said that it could be caused by the y pipe, idk if thats true or why he thinks that but thats what he said
Ranga14
Car: Boosted 08 Altima Coupe 3.5
BzOaY wrote:Thanks, so yesterday my check engine light came on again...ran the code it was the idler again...cleared the code and my cruise worked...? :confused: :confused: :confused:
Hmm, the ypipe, no... Unless it was installed improperly. Exhaust leaks will throw the check engine light.
BzOaY
ill check for leaks but im pretty sure i installed it correctly and bolted tight
