NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Jan 03, 2004 5:06 pm
you need to check and see if the main harness has the connectors for the cruise components at the dash and under the hood. a really good way to tell if they included the harness is, go to your relay box under the hood look for the slot for the ASCD relay. if the socket for the relay is there it has been pre wired. if the hole is empty and there is no socket to plug a relay into it is not there.
