cruise control ???????????????
motaro9424
Car: 240sx convertible
if I swap my transmission from auto to 5 speed manual my cruise control still working fine... or is not working at all... because I like to still have the cruise control after the swap..
Thank Youuuuuuu
Modified by motaro9424 at 7:20 PM 9/22/2009
Klits562
Car: white s13 coupe
there is a sticky at the top of this forum for the auto to manny swap and it looks like they had alot of trouble getting the cruise control to work.maybe you can do the swap and then get the cruise control off a manual 240 and swap that on. It seems that there are wiring differnces in the auto and manny cruise controls
sainifabulous
Car: 1992 240sx HB - 1991 240sx HB DOHC, SR20det waiting to be dropped in.
i heard if you dont touch the brake pedal it will work for sure if you just cut the brake pedal instead of putting in a manuel brake pedal it will work.mine doesnt work i have a 5 spd pedal i think im gena get the sensors of a auto brake pedal maybe it should work
