cruise control
smitty7
Car: blacksmithing, fishing
We have a '91 240sx auto trans., and the cruise has quit working. I've checked the fuses ( as near as I can get my watermelon head down there to see) and can't see one marked for the cruise. What would be the next step to track down this problem?
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
the cruise control servo, its wiring, and its contol unit.
the fuse for cruise may be under the hood with the relays.
NISTECH
check the cable adjusters at the throttle body make sure the lock nuts are secure and the cable hasent fallen out of the lock plate. does the light come on on the dash when you turn the cruise on?
alex240sx
Car: 91 240sx
mine does the same thing but the light dosnt come on, on the dash and i cant fined a fuse either i just gave up
NISTECH
alex240sx wrote:mine does the same thing but the light dosnt come on, on the dash and i cant fined a fuse either i just gave up
one of the 2 switches on your brake pedal has probably gone out. one switch is for brake lights and the other is for ascd(auto speed control device) if your brake lights work unplug the switches one at a time till the brake lights dont work. when that happens you have found the good switch the other one is the bad one. unless you have a manual trans then the switch on the clutch pedal is the likely bad one.
smitty7
No, the light does not come on when the button is pushed. Thanks everyone for the suggestions, I'll start on it this weekend.
smitty7
