I totally understood that he was talking about the switch on the dash. My proposed scenario would be highly unlikely if the buttons were off the wheel because it would be almost impossible to accidentally hit them when turning.fueler wrote:hes talking about the on/off switch in the dash, near the power mirror controls. Not the accel/decel buttons on the wheel.
It wouldnt be dangerous cause cruise control disengages (but doesnt turn off 100%) anytime you hit the brake. So bmlawless scenario would never happen with this mod done. Its a great idea, wish i could answer your question.
Post the results.
interesting, i didn't know that. Ill try it out.bmlawless wrote:When you hit the brake, it disengages the cruise, but it does not reset the last speed setting. If you hit the brake, then hit resume, it will take off. Try it on the freeway.
SnowSurfLax wrote:Not exactly. If you hit cancel while using the cruise, it disengages it just as if you hit the brake. If you hit it a second time without hitting resume or set, you completely clear the memory.
OK, just for the heck, I took it out for a spin and found out: hit cancel twice or many times will not clear the memory; but hitting any two of the three buttons at the same time will. I guess this is the fail-safe feature.bmlawless wrote:The only way to clear the setting is to turn off the vehicle or turn the cruise control switch to off.
I guess I must not be expressing my thoughts properly. Are you saying that your Honda has NO main switch? You should have Resume/Accel, Coast/Set, and Cancel plus a main on/off position.chaonis wrote:Also, I don't think accidentally hitting the RESUME is a problem. At least HONDA does not think so. My Civic's uses the toggle switch and my mod makes the switches on the wheel behave exactly the same as the ones on the Civic's. Modified by chaonis at 11:36 AM 1/8/2009
most hondas have it set up so that the switch is either on or off all the time..... it does not reset to off when you turn the car off, like our nissans do. In a honda you leave it on and forget about it.bmlawless wrote:
AMEN! I don't know why all of the switches aren't lit. I can't tell you how many times I've turned on my rear wiper trying to turn on the heated seats.fueler wrote:the worst part is that the switch isnt lit. try finding it while on the freeway in the middle of the night. its impossible.
