Cruise control remote
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
etiennel
Hi,
I want to know if it's possible to put a OEM cruise control on a Versa? I know we can do it in a Mazda 3 (only with steering control and brake switch) so I think it's possible in a Versa.. I'm sure I can buy a OEM Nissan control on ebay...
Thanks a lot!
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
The steering wheel will fit, but without looking at your car it's hard to say that the wiring between the wheel and the Engine Control Module is there or that the ECM would understand that you now have controls in place. You may have to change the settings inside the ECM, which really should mean that you should find a donor car with cruise control and the same type of transmission you have (auto, CVY, or manual) and get the ECM and steering wheel. That will limit the amount of obstacles you would run into making it work. It's an experiment no one has tried yet.
etiennel
Thanks... Ok, I will find the donator here and looking how the wiring is done...
I've done it on my mazda 3. It was so easy... just plug and play... for a big 40$ for the controls!
http://www.mazda3forums.com/in...816.0
Thanks!
Return to “Versa Technical Discussions”
