cruise control question
z-goose
Car: 1990 nissan 300zx (NA, 5speed)
Just bought a 90 300zx NA and am trying to fix as many things myself before going to a professional. Am trying to locate the cruise control (ASCD)relay. Manual shows it somewhere behind the glove box??? Could anyone give a newcomer some help. Have already fixed 3 big rust spots, leak in t-top, bad fuel gauge and 4 new speakers.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the ASCD relay is located underhood in the relay box behind the drivers side headlight (plastic cross looking thing)
the ASCS control unit is located on the passanger side floorpan, pull back the carpet and you'll see a piece of plywood, remove the screws holding it ina nd you'll uncover the ECU, remove the mounting screws for the ECU and under it you'll find the ASCS (it's the one on the left)
hope this helps, welcome to NICO
z-goose
Thanks for the info, will work on that relay in the AM and will get back to you with the results
