Cruise control problem
jimbo409
Car: 2002 qx4
I have a 2002 qx4 with the adaptive cruise control.When I push the cruise control switch both lights come on and when I go to set the cruise,nothing happens.Will not engage,has anyone had this problem.When I go to put on the cruise both lights come on.Thanks Jim
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Do the lights (or one light in particular) blink? If so, how many times?
Inspect the vacuum hose from the cruise actuator (passenger side, gray box right next to the fender) for damage.
Welcome to NICO.
fastpakr
Car: 2001 Infiniti QX4
Check the cruise control info on page EL-260 here:
http://www.nicoclub.com/FSM/QX4/2002/EL.pdf
jimbo409
Car: 2002 qx4
No blinking lights.they both are on
pday
Jimbo,
did you fix this problem? I have 2001 qx4 and having cruise control problems as well. Cruise light comes on in the dash but the set button will not engage. I pulled the field service manual and there are a lot of moving parts to this but I was hoping it would be a simple fix. Did you manage to fix your problem? Any guidance would be appreciated. Thanks.
-Phil
Silverhorn
Car: 1999 Infiniti Qx4
I"m having issues with my cruise control. The cruise "on" light doesn't come on at all. I read somewhere that the horn and cc are on the same circuit but the horn works. Any ideas?
atraudes
Car: 2001.5 Infiniti QX4 4WD
Check the #11 7.5A fuse first. If that looks fine, start running down the troubleshooting steps outlined in the FSM on page EL-172 on the "ASCD cannot be set. (“CRUISE” indica- tor lamp does not ON.)" line.
Silverhorn
THanks for the post. But how do you remove these fuses. I would think that they would just come out once depressing the visible clip.. But I did that and the damn thing don't budge. Last time I saw fuses anything like this I had to take the whole box apart because they were bolted in. Pls say it isn't so.
atraudes
On mine there's a small white puller mounted on the corner of the box. You pull that out, push it over the fuse, and pull. If you don't have one of those, some needle nose pliers will do the trick.
It's just a small brown fuse that has 7.5 stamped on the end like the third down on the left, correct?
If not, can you post a picture of what you're looking at?
Silverhorn
Oh, I already checked that one. I was talking about the one in the engine bay marked ASCD (automatic speed control device). THe big ones with the blue plastic caps over them.
atraudes
Sounds like the relay. I am 90% sure you can just pull it out and that it isn't bolted down or anything. Every relay I've ever removed has given a good fight.
atraudes
Another really fast and easy thing to check is your brake lights. Check that they turn on with the headlights, they get brighter when the brake is pressed, and specifically check that each of the individual bulbs in the top window mounted brake light function. The cruise control depends on one of the brake light bulbs (can't recall which one). If the bulb is blown, the cruise control won't work.
Silverhorn
Ok. I'll try all that tomorrow. Thanks for the replies. Its bedtime here.
