Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Mon May 03, 2004 10:39 pm
Yea, you'll need to switch TB's more than likely, that's easy enough (and the KA one is bigger). You will however have to re-wire your TPS since the KA and SR ones are different (also very easy).
I assume your using a KA lower harness, so your speed sensor should still be hooked up the the crusie system.
That's about it, I just about had mine working (the stepper motor for the cruise was busted, everything else worked) but I swaped out steering wheels and never looked back.
hope that helps.
Paul
