The cruise control on my 1993 Sentra SE died a few months ago. The green light switch appears fine. When I turn it on, it glows steady green. When I hit any of the controls on the steering wheel, nothing happens. I checked the rubber things on my brake and clutch pedals, and they're intact and fine. I also pulled the rubber hose off the vacuum control module (i'm assuming that's what it's called) and the throttle cable, and it appear fine, too.
Any ideas what might be wrong? I tried to remove that vacuum control module, but I can't get it off. It's in an awkward position and I can only get the top bolt off.
Thanks,-Tom
