Cruise Control blinking
clemson99
Car: 93 Infiniti J30 Green (daily use)
06 Infiniti M35X Gray (week end)
I have a 06 Infiniti M35X. I have had it since February 2012. Every once in a while the cruise control will start blinking on the dashboard and stop the cruise control set speed. It can also start blinking while being on but not set to a control speed. Has anyone experienced this before? I will take it to the dealership as I have a bumper to bumper warrenty but would like to know with what I'm dealing with before I take it in to be looked at.
atlM35
The only times that my cruise control will do something like that is when the wipers are on or if I turn off the VDC.
Sometimes, if the sensor is dirty in the bumper, it will have problems as well.
If those aren't the cases for you, then the system need to be checked.
clemson99
You are correct on it occuring when the wipers are on as if it rains hard enough the cc will disengage. This is occuring during clear skies as it happened about 4x this morning back to back before it held the cc. Where in the bumper is the sensor located? I just cleaned my car about 5 days ago and I don't drive through any mud or off road.
atlM35
I forgot to ask, does your car have adaptive cruise control?
If so, if you stand in front of the car facing the front bumper, you'll see it just to the right of the center cutout at the bottom... rectangular clear plastic piece in the black plastic.
clemson99
yes it does have the acc. i will go look for it after work. the lens may be dirty from the outside.
antzrus
Car: '06 M35x Premium/Obsidian/Bourbon/
Rosewood/XM/Tint/
ClearBra/SteelSkidPlate/Genuine CoCo Mats/Michelin CrossClimate2/Nav Hack/M-1
I notice a similar experience when heading directly into the sun-the adaptive cruise control blinks and stops working.
moedawg140
Car: 06 M35 S (Adv. Tech)
LI Quad
G37 BBK with H&R DRS
(15mm F, 10mm R)
Focal 165KRX2 (F)
Infinity Kappa 63.9i (R)
Alpine Type-X 10"
JL HD900/5 (sub chnl.)
RF CPCD10-03
Morimoto 4,300K H11
It sounds like the light sensor on the upper dash is detecting 'glare', meaning, if it is early in the morning and the sun is hitting you and you try to use ICC, it will not operate until the light sensor detects there isn't any more glare.
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
antzrus wrote:I notice a similar experience when heading directly into the sun-the adaptive cruise control blinks and stops working.
You beat me to the punch, Antzrus! :)
clemson99
thanks. if this is the case then i don't see a fix for this. i'll have to pay attention the next time it happens to see how the sunlight is toward me or not.
mexillis
Car: M45s
the fix could be to use the non icc cruise/ regular cruise control
GenericM35
Car: 2006 M35X
mexillis wrote:the fix could be to use the non icc cruise/ regular cruise control
How? I've tried doing this before, but I haven't been able to take it off, so I usually just leave it set to the closest following distance...
antzrus
Rosewood/XM/Tint/
How about the furthest..? :)
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
Page 19 of the Infiniti M Quick Reference Guide states (I'm paraphrasing for topics we discussed):
The ICC System (if so equipped) can be set to one of two cruise modes:
- Vehicle-to-vehicle distance-control cruise
- Conventional fixed-speed cruise control
Setting conventional fixed-speed cruise control
1. Press the CRUISE ON/OFF button and hold for more than 1.5 seconds. The CRUISE indicator light will illuminate.
2. Accelerate to the desired speed.
3. Push DOWN on the COAST/SET switch and release it. The CRUISE SET indicator light will illuminate.
Note: There are certain conditions under which vehicle-vehicle distance-control and/or fixed-speed cruise control cannot be set or will automatically cancel. Three such conditions are shown below.
- When rain, snow, or dirt cover the system sensor (located in front bumper opening).
- When the windshield wiper is operated at low or high speed.
- When strong light shines directly on the front of the vehicle (i.e. sunrise or sunset).
Switching between the two cruise control modes:
When one of the two cruise control modes is in use, you must first turn the system OFF, and then ON again (as instructed above) to select the other cruise control mode.
jepaul2438
Car: Q50
Brake pedal switch.
