Cruise Control and 5 speeds? Possible?
s14junky
Car: 95 240sx
Anyone running this setup?.. particularly after a 5 speed swap? #1 is it possible, #2 was there any trouble encountered to make it work? I do a lot of long distance driving and will continue to after my swap. Ive just never heard of cruise on a manual. Was it offered OEM?
Fenvy
Car: 2005 350Z Base 6MT
yes it is offered stock on my s13, I am sure other cars are the same too
my 5speed integra also had cruise control
e_c
Car: 1990 240sx
i have 5speed from factory, to get cruise to work, i have to lift up (towards me) the clutch pedal with my foot and then set the coast
Toshima
Car: 93 240sx, 93 sc300(m/t)
I dont have cruise control on my 240sx but I have it on my 5 speed 2g eclipse.
benemorius
Car: s13, s13, eg, e36
I've never had a manual without cruise control...
s14junky
Car: 95 240sx
Thats great, what about the rest of my question??
navysnail
it was offered OEM. i don't know what exactly would be required to make it work, but I will say probobly the acuator, CC throttle, buttons and associated wiring.
s14junky
Car: 95 240sx
Snail...tnxI was thinking more like..would you still use the brake to interupt it? Does the clutch action also interupt it (ie on a downshift). Those are the tech Qs i have mainly. Ill have to scour my FSM electrical schematics. Thanks
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
My 5spd S14 has cruse control.
Works quite nicely too, I use it a lot on the highways.
s14junky
Car: 95 240sx
No Kidding???I thought maybe you used it in the alley or a school zone. duh
Maybe my question is too complicated. Im trying to find out if anyone has done a 5 speed swap and also retained the cruise. If so ...how?.. sheeze
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
If your car already had it and you want to keep it with a 5 speed swap all you need is the clutch pedal cancellation switch. You can still have cruise without the clutch switch but if you push clutch in the engine will proceed to redline. The cruise is non-transmission bias so if it worked before then it still should.
s14junky
Car: 95 240sx
THANK YOU!! Finally someone who gets it! Thats the info i needed.Would you mind emailing me? I have a few more questions.Im in riverside...not far.Do you have any parts for sale or barter?I also have 2 pearl white 95s
Thanks
[email protected]
ddgsxr504
I can email you when I get home from work which is like 5pm. I do have a set of Sprint lowering springs for sale or will trade so let me know what you got. I'm willing to deliver the springs if you purchase them since I need to take a relaxing drive plus we can oogle each other's cars.
s14junky
Car: 95 240sx
Spoken like a true s14junky.
ddgsxr504
coolbone28
there should be a brake and clutch cancel switch. 95 s14 has it. works great.
nukeone
Just for clarification; when you say "swap," are you simpy referring to the auto to manual transmission swap or are you referring to an engine swap? If the latter, I haven't found an SR that had factory cruise although the RB from the Laurel and Cefiro came with cruise. The issue is not the electrical side, because you can retain the electronics (ASCD box, actuator/vacuum pump, etc.); the issue is usually the throttle body. The non-cruise engines only have the single connector for the throttle cable; the factory cruise engines also have the second connector for the cruise/ASCD actuator cable. For the manual transmission swap, you would need the clutch inhibitor switch circuit which works just like the auto transmission neutral/park switch to disengage the cruise. There are aftermarket cruise devices that can be installed on basically any vehicle, regardless of the throttle body design/configuration.
