meminto »
https://forums.nicoclub.com/meminto-u95701.html
Sun Dec 06, 2009 10:48 pm
Correct, mine does not yet run so I can't give feedback on how it performs, I would like to do a couple of thousand km too before I provide feedback on its ability to keep the cas under control... The only thing I will be looking for is pressure on the shaft and issues with breakages...
It bolted on ok, everything lined up where it needed too, it has adequate clearance between my tomei gears and the plate itself, the cas was a snug fit is a little stiff to manouvre but it improved significantly when I polished the cas up..
I think it is a nice looking setup..
However one piece of feedback I can provide is that the backing plate needs some sort of a mount, so you can move the cas plug lead away from the rotating inlet gear..
It does have a threaded rod (i cant think of any other way to describe it lol) that you can use your original tabs to lock the lead away (although I used my own solution), it would be a value add to not use threaded rod, but create an anchor point during manufacture for a cable tie instead..
You can see the anchor point i am using, that is the rod with the thread, i think it is a 6x1mm thread, but i need to double check....
Yeah there is a lot of the cam/belt area exposed, I have an alloy bash plate, so the risk has been significantly reduced for anything flinging up from the road..
