idahotuner wrote:well we are on the topic of the transmission cross member what size are the bolts that go from the transmission through the crossmember because i lost my nuts for them and need to buy new ones.
they look like 10mm but i am not sure.
It's a 17mm head and I am pretty sure it's a M10X1.25 thread (like everything else on the car) with like a 25mm length give or take... put that should be the right thread cause I had to replace other 17mm bolts and that was their thread/pitch. I put in a 40mm length or a 30mm length and it fit perfectly fine (along with 2 washers and the nut to go with it.) I put the nut on the bottom side.
Modified by vocationalzero at 9:01 PM 2/13/2008
