Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Jul 22, 2006 4:18 pm
Bingo, the 240sx uses a 24 group battery, which is also offered in a reverse configuration (24R, 24F, whatever, depending on where you go). Sorry kid, that is a tough break. You should replace any blown fuses and test the ignitor. If it starts, go through a running check on your other circuits. You also probably blew the diodes on your alternator. Also, check your A/C clutch diode (I do not have a chart in front of me, it may not exist). Diodes do not like reversals.
