Crossed Thread with the engine covers?
All things Altima Coupe.
fenderpicks
Car: 2010 NIssan Altima 2.5s
Hey everyone today i crossed thread 1 of my engine cover's screw "The one that requires the hex key"
Since i cant take off the engine cover unless the screw is off... how do i fix this issue lol
PapaSmurf2k3
Site Admin
You should still be able to remove the screw even if you cross threaded it. If not, you'll have to drill it out.
If that's the case, then you might want to put in a heli-coil so you can still use that screw anchor.
fenderpicks
I think i used the term crossed thread wrong lol,
I meant like the top thing that u put the hex key to losen and tighten is jacked up and i cant get the screw out lol sorry
PapaSmurf2k3
Site Admin
Oh, like the head is stripped. Yeah, you'll have to use an easy out, or drill the head off. Once you get the head off, you should be able to remove the cover, and unscrew the rest of the bolt by the shank. Should come right out (unless its cross threaded ;) )
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Rightey Tightey
Lefty Loosey!
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Needle nose vise grip FTW!!!!!
fenderpicks
So how do I get the screw out lol?
And were can I buy replacments of that screw from?
trigger_storey
Take a dremel and cut a slit on the top of the bolt. Then just take a flat head screwdriver and take it out. For replacements you can find them online or just take the one that isnt stripped to any hardware store, find a screw that matches it in size and buy 2 of them so you can replace both of them and have them match.
lavon_andy
Car: 2010 Nissan Altima Coupe
I thought you could also fit a 9 or 10 mm socket over it and just do that instead of using a hex bit. I can't remember but I thought that's how I did mine (2010 AC though). I might be mistaken though, cars outside in the cold and im lazy...
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
LongBeachCoupe wrote:Rightey Tightey
Lefty Loosey!
:rotflmao
PapaSmurf2k3
Site Admin
fenderpicks wrote:So how do I get the screw out lol?
PapaSmurf2k3 wrote: you'll have to use an easy out, or drill the head off. Once you get the head off, you should be able to remove the cover, and unscrew the rest of the bolt by the shank. Should come right out
:squint:
old_skool_2004
Car: Altima
The best way to remove a stripped screw is using what is called "easy-outs". There are different names for them. You can find them at Sears, Autozone, etc. Make sure you install the right pitch thread when you replace it or you will damage the internal threads and that NOT GOOD.
PapaSmurf2k3
Site Admin
Eh, even if you f*** it up royally, you can always just drill the whole damn thing out, remove whatever it is you're trying to remove, then clean the hole and put in a helicoil. Its really not that hard.
