Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Oct 28, 2003 8:22 am
Except in one VERY narrow case of vented and lightly drilled [like powerstops] where in rain the steam may escape thru the holes into the vents.......but very very rare situation and low significance.........might be worth 2-3-even 5% reduction in distances.
Weight the rotors if the drilled weigh the same as non drilled you know the metal is denser. Even 5% weight difference [8 ounces] is significant as it will mean a 20-40F higher rotor temperature in a single 80 mph to zero stop!
Remember the brakes have to be 2-3-4 times more powerful than the engine.......you acccelerate the quarter in 15 second but need to stop in 4 seconds. A 300HP car need 1200 HP brakes.........and brake horsepower is a pure function of all rotor combined weight.
