CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Thu Jun 26, 2003 4:05 pm
Quote »are you guys sure that the FWD water pump can stand up to the requirements of the RWD with clutch fan??? i broke two already on a RWD DE!!! i am thinking fo going with an electrical water pump, IF i can;t get a brand new O.E. RWD CA18DET water pump.[/quote]NO ONE really answered this, i have briken a couple FWD pumps, and have eventually re-used the pump that i removed that was leaking through the bleed hole..
the problem with the FWD water pump is that it doesn;t have the "c" clip below the bearing on the shaft to stop the blades of the pump from hitting the inside of the block when the engine is under load from driving and the clutch fan.
i am hoping that the ones i got were jsut cheap ones, cause NISSAN sucks here locally and told me they dont have OE replacements so "hard luck"
has anyone used a FWD water pump on a RWD engine that uses/used a clutch fan to kinda get an idea if it can take the load.
I am not going to be using a clutch fan, but it still got to take the load and high RPM....
i thhink the clutch fan broke the FWD pumps i got.
i think i will post the broken water pump so ya'll can see the damage..
please someone let me know.
now ordering the gasket rebuild kit, oil pump, and hopefully water pump.
thanks guys
