Cross member, Got it off, can't this one get it back on...
bboyresaluu
i had to replace my cross member, so i took it off, and got a newer one, to put back on.
wont go on. about a 1/2 - 1 inch clearnance on the 17 mm bolts, and the rack and pinion doesn't allign.
my first instinct is that the crossmembers or different, but their the same.
then i thought maybe my frame is bent, my frame looked striaght tho.
so i figured that since it was so easy to take my old cross member off, then it would theoretically be just as easy to put back on (assuming a bent frame)
nope.
theres about a 1 inch clearance between the 17mm bolts that lay above the control arm, on the cross member, and the same with the OLD cross member.
any ideas on why?also on why i was able to take my old cross member off 'easy' and unable to put it back on?
thanks for any help and support.
wcbjr
Car: KA24E / hatch
Can you put the old one back on? Maybe something shifted upon removal. Got any pics? You sure they are the same?
bboyresaluu
yeah, i can't even get the old one back on.
and yeah, their both the same,
i have a single came pignose.the one i bought came off an sr clip
other than power steering line brackets, which makes no differance. they are both the same
3 weeks 2days and counting with me being without my car.
wcbjr
Car: KA24E / hatch
Something must have shifted. Get another pair of hands to shove things around while you piece things together.
Is the car jacked up on both sides, so as to not torque the frame?
bboyresaluu
sigh* many figured i didnt jack the motor. so when i removed the cross member, the motor is weighing down. thus the 1/2 inch clearance.
