240_Keyy »
https://forums.nicoclub.com/240-keyy-u3357.html
Mon Jul 28, 2003 7:27 pm
Actually the holes and slots have nothing to do with heat dissipation. The holes are there to protect agains outgassing (some organic pads do this, but it is basically irradicated nowdays) and the slots are there to clean the pad surface, they don't actually improve anything.
You may ask "why do race cars have them then?" and the answer to that would be quite simple. Sometimes racecars drive in the rain and the rotors usually have some type of ducting blowing onto them. If they are driving in the rain and slam on the brakes, the rotors heat up and vaporize the water on them. This pressure has to go somewhere so it goes through the holes in the rotor. Sometimes these ducts will spray mud onto the rotor surface (think rallying) so the slots are there to clean the pad surface .
Furthermore, the rotor's integrity is compromised whenever you drill or slot it. This is because as you heat up the rotor, the material expands, but the area immediately around the holes or ends of the slots will be slightly cooler and will not expand in exactly the same way. Over time this causes stress in those areas and often leads to cracking. And cracking on a rotor is not a good thing.
They are of absolutely no use on a street car and I will NEVER put a drilled or slotted rotor on my vehicles...
Zero- The holes do not help dissipate heat, in fact the point of a rotor is to absorb heat and then radiate it back in the form of infrared light (longwave radiation) therefore if you remove rotor material from the rotor, it cannot absorb as much heat and radiate as effectively. Besides, the pad material determines the amount of fade, not the heat of the rotor.
SmithSR- You are right
So anyway, the moral of the story is that x-drilled and slotted rotors are worthless unless you actually have an outgassing problem, race excessively in the rain, or rally all the time.
EDITED: fer spellin erras
