critique my setup, ka24e-t for 14's in 1/4 mile
goldenchild
Car: 90 Nissan 240SX KA24E-t go bye bye, gotta another in the works
jgs manifold, 8:1 fmu, walbro fuel pump, bov, i/c, 300zx t3, gauges, 7 psi, is this good for 14s in the quater
DaveEEE
You'll need a good *** 60ft and possible a limited-slip. But it'd be close....
3rD GeAr
Car: cars
maybe, good traction and u should be set for 14s.what about injectors? stock?and a good exhaust
red240ne
Car: mmm...donuts
You could run that setup on 4psi on stock injectors, get a VLSD, a good set of rubber, and you'd easily be in 14's. Shoot for 13's though. Believe me, you'll want it.
goldenchild
stock injectors with fmu and fuel pump for right now, stock exhaust. This is a basic setup until the end of the year, 2004 plans are built motor, t04b, 370cc or larger injectors, s-afc, z32 maf, test pipe,2.5 exhaust, vlsd
red240ne
Car: mmm...donuts
Well, you're not going to be able to run on the track until next spring anyways. Especially since you're in North Dakota, LOL. So it doesn't even matter if you run 14's right now.
MikeMurphy
Car: Guess
maybe im just totally wrong, but I think your T3 is going to be your restriction. Im going to say 14.6 possibly.
goldenchild
yes ur right I wont be able to do anything until the spring, so Im deleting the t3 from the the set and going t04b
SingleCamSam
That setup is easily good for low 14's IF you do your job right.
